Photos NEEDED! of a machine with brake on motor not turntabl
12jslater
Post by 12jslater »
I need a photograph of machines motor that has a brake which stops the motor instead of its turntable.
Please respond
Roaring20s
Re: Photos NEEDED! of a machine with brake on motor not turn
Post by Roaring20s »
The Excelda portable works that way.
Scroll down to the image of the motor, here...
http://rainer-urich.de.tl/Thorens-Excel ... mophon.htm
James.
alang
VTLA
Personal Text: TMF Moderator
Post by alang »
The Standard Model X / X2 and other Columbia machines use the combined speed control with plunger brake. Sorry, could not find a cleaner picture. :oops:
Hope that helps.
Standard X motor.jpg (91.65 KiB) Viewed 1981 times
Post by Phonofreak »
What kind of machine are you looking for?
12jslater wrote:I need a photograph of machines motor that has a brake which stops the motor instead of its turntable.
Please respond
Many Brunswick machines are as you describe, with braking done at the governor. Sorry, no pics...
12jslater
Post by 12jslater »
Phonofreak wrote:What kind of machine are you looking for?
Please respond
It is a decca dulcephone a GENUINE 1914 trench gramophone and I need to create a new brake mechanism as mine is completely missing, I also would like the start stop plate.
Thanks, Jake
