Before-After Victrola VV-VIII
CDBPDX
Personal Text: A Hobbyist Specializing in Sales and Repair of Spring Motor Phonographs
Post by CDBPDX »
Just brought home a nice VV-VIII that is pretty grungy. Thank goodness for Howard Restor-a-Shine!
CDBPDX
Re: Before-After Victrola VV-VIII
Post by CDBPDX »
Another before-after set....
barnettrp21122
Post by barnettrp21122 »
Looks really nice! Remarkable how much some simple cleaning will do! Please post final pictures!
Bob
Victrolacollector
Post by Victrolacollector »
I have a mid-teens VV-VIII and mine runs kind of noisy, I am curious how your motor sounds? I am wondering if I this is normal?
CDBPDX
Post by CDBPDX »
Victrolacollector wrote:I have a mid-teens VV-VIII and mine runs kind of noisy, I am curious how your motor sounds? I am wondering if I this is normal?
My motor is quiet as a mouse, very unusual for this type of motor as they are almost always a little noisy. A noisy motor of this type is usually a spindle gear that is adjusted a little too high or low on the governor shaft, or it could be a worn spindle gear such that the teeth no longer smoothly mesh with the governor shaft worm gear.
Before tinkering with the governor, you should make sure the springs are completely unwound then remove the spring barrels. This will allow you to adjust and test the adjustments without winding it up.
Good luck!
EdisonWizard
Post by EdisonWizard »
I was curious how Howard's works. Is there any prep before you use it? Do you just try your best to match the color? Been thinking of trying it on some stuff but kinda scared lol
I'm guessing this is the same as restore a finish? Or maybe I'm confused.
J.F.
CDBPDX
Post by CDBPDX »
EdisonWizard wrote:I was curious how Howard's works. Is there any prep before you use it? Do you just try your best to match the color? Been thinking of trying it on some stuff but kinda scared lol
Howard Restor-a-Shine is a polishing compound, different from their Restor-a-Finish. The 'Finish' comes in many wood hues and neutral. First, though, I like to use the 'Shine' to clean the surface. Don't know why, but the 'Shine is not usually on the shelf with the 'Finish'. My last 8 cans I bought off Amazon.
It cleans down to the shellac and polishes the shellac. I also use it on enameled metal surfaces. The 'Finish' is great for blending off color blemishes.
P.S. - It also requires significant elbow grease.
CDBPDX
Post by CDBPDX »
here is a cleaning progression.
tomb
Post by tomb »
the years of soot , tobacco smoke, and pollution really can screw up a 100 year old finish over time.. With a lot of elbow grease and luck we can bring the finish back rather well. It looks good and came out well. It is nice to brig it back to original with out modifications. Tom B
CDBPDX
Post by CDBPDX »
Got the exterior done, still working on the interior. The top had something black on it, I scraped some of it off all the way down to the wood and the wood is black, too. Just going to have to live with it, not up to a full refinish...
