Fonotipia operatic key-note tuning band
- Torjazzer
I recently acquired some Fonotipia operatic records from a local collector. One disc by the forgotten (and forgettable)mezzo soprano Armida Parsi-Pettinella has a key-note tuning band between the session and run-off grooves. This particular recording is from Il Trovatore. Can anyone tell me which key note this represents?
- Lucius1958
Re: Fonotipia operatic key-note tuning band
Generally, the tuning note for an orchestra is A. If the record does not have orchestral accompaniment, then it's more difficult. An audio comparison between the main recording and the tuning band, using a reference to the score, might prove useful.
That said, sometimes tuning pitches varied from orchestra to orchestra; and arias might even be transposed to suit a particular singer's voice...
- OrthoSean
A is correct. Use a pitch pipe and match the tuning band to "A". Fonotipias play all over the map. I have some that aren't in proper pitch until slowed down to 68 and others that need to play as high as 82.
Sean
Sean
- Torjazzer
Thank you so much for your replies. "A" works very well for this record with the platter spinning at 76 RPM.
A little off topic, records made by the contralto Dame Clara Butt for UK Columbia often had the key printed on the label. I read somewhere that this was to enable the owner to accompany her on their own piano, but as the key appears on records with either piano or orchestral accompaniment I think this explanation unlikely.
- cb.jpg (100.38 KiB) Viewed 1406 times
- Torjazzer
That is interesting. This is an electric pressing so I cannot imagine that the key was mentioned in order to calibrate the turntable; not so easy with early electric machines.epigramophone wrote:A little off topic, records made by the contralto Dame Clara Butt for UK Columbia often had the key printed on the label. I read somewhere that this was to enable the owner to accompany her on their own piano, but as the key appears on records with either piano or orchestral accompaniment I think this explanation unlikely.
