I need help on how to relube my springs..
OldRestorer
Post by OldRestorer »
I have a Royal Phono and the springs are clogged. The Phono keeps slowing and then the spring will jump making it play faster. Then do it again and again..
How do I re lube? Do I have to remove the springs?
What do you guys use to lube?
I looked online but did not really know what to look up.
Thanks for any suggestions.
Kirk
It's not what you say... It's what you do...
HisMastersVoice
Auxetophone
Re: I need help on how to relube my springs..
Post by HisMastersVoice »
There should be a ton of info on this right here. And just as many opinions!
See the sample search query below:
http://forum.talkingmachine.info/search ... ing+grease
Dave D
Post by Dave D »
I am a firm believer that the springs should be removed and cleaned. You can inspect them for damage at that time. If you don't clean them, you will probably find yourself asking more questions about why it won't work well.
Dave D
As Dave states, removal and cleaning is the very best way to go.
OldRestorer
Thank you all for the info and that link.
If you know what to google the information is out there.
I will fully redo it...
Kirk
travisgreyfox
Post by travisgreyfox »
Check out this series: https://www.youtube.com/watch?v=6R9i7zp-v9s
After watching that you should be able to tackle the job.
burke
Post by burke »
That youtube video and I became very close pals when I re-build my first victor.
No end of graduate for that amazing tutorial!
