I have this Odeon soundbox for a while but cannot use it as the back is missing.
Could someone post a pic showing the back of this reproducer? As well, any info on this Odeon Concert reproducer will also be welcome.
Thanks,
Jeff
Odeon concert soundbox
phonodesbois
Layla
Layla
Re: Odeon concert soundbox
It looks like that you need to assemble the soundbox with 3 screws to the arm. I also found same looking victor soundboxes with 2 back screws.
Maybe you can make an universal adapter to make it fit to your gramophone.
- 1.jpg (31.63 KiB) Viewed 1658 times
- 2.jpg (40.27 KiB) Viewed 1658 times
- 3.jpg (35.92 KiB) Viewed 1658 times
- 4.jpg (119.12 KiB) Viewed 1658 times
estott
probably a "European Fitting" - a tube which fits into the arm, attached to a flat plate
