Outside fabric issue on VV-35
Victor A
Personal Text: "Are you suggesting coconuts migrate?" - Graham Chapman
Post by Victor A »
Hi all,
So my VV-35 has an outside fabric cover, that is torn in spots along the top left edge of the lid. It looks like there was a middle section that was completely torn off the machine, and now, when I try to align the two ripped edges of the fabric, there is a gap between them, so they won't meet.
Any help?
Thanks
SOUSA, The March King, says:
Re: Outside fabric issue on VV-35
Post by Phonofreak »
Here is what I have done with torn or missing fabric on portables, record cases and such. I go to a fabric store and get as close to a match as I can. I cut and fit the missing pieces. I glue those down. Then I glue the torn fabric down. After everything is dry and cured, I use good old fashioned Kiwi black shoe polish. I smear it on thick. I let dry, and buff. You may have to put on a couple of coats. The thick coatings hide the seams of the joined fabric.
caratunk
Post by caratunk »
Victor A wrote:Hi all,
Any help?
Thanks
im no seamstress but what about some kind of border around it to hid the section that wont meet? like ribbon or colored lace or braided material like they use on shirts western wear..just got to think outside the box ..your not ruining it just embellishing the worn spots..you could even tea dye it to make it look older..and blend in with the orig fabric;];];]and for glue use the tacky glue. for fabrics in the craft isle ;];];];]
Victor A
Post by Victor A »
These are some good ideas. Thank you both!
I think Harvey's advice is good. I have used this method on several fabric covered cases. The only difference, is that I have used KIWI Scuff Coat liquid shoe polish and when the repair is made, I coat the entire box with it to make all of the areas blend together and appear refreshed. Then, there is no difference between the repaired area and the entire case, since they are all the same color...
