I am cutting back on the amounts of records from the earlier acoustic period but don't quite want to not still play some. My large Brunswick is actually overwhelming in the small living room I have. Some time back I found a rather odd tiny Sonora from 1910 I believe the ad that showed it was from. The little horn opening is only about six inches across and five or so high in an oval shape. You can listen to it with Caruso and not have your ears buzzing or overwhelmed by the volume. I find that appealing. The tiny crude wooden horn is so basic its almost laughable. I wouldn't want an outside horn machine, takes up too much room visually. I am curious if some of you have a favorite for good sound in a table model smaller machine? Some portables seem to also provide rather airy and good sound, but they can also be pretty loud in a enclosed space. Any thoughts on what you might suggest?
Larry
Which small machines have decent sound?
larryh
estott
Re: Which small machines have decent sound?
The VV-IV is good sounding and very reliable. If you can get one I'd recommend the HMV 109 - similar to the Victor in size but it handles electric recordings a bit better.
In American portables, to my experience the VV 2-35 is great, combining fine sound with compact size. The UK counterpart is the HMV 102 which is even better, though the 101 is not to be slighted
bigshot
I use my VV-2-65 suitcase phono for that sort of thing. It's portable and it plays just about any kind of record well.
EdiBrunsVic
The VV 2-55 also has a good sound.
Many British collectors, myself included, rate the HMV Model 130 the best table gramophone ever made. It has the No.5a soundbox, the No.32 double spring motor and a horn of exponential shape. Not easy to find in the USA but well worth seeking out.
For acoustical recordings, small, compact, but decent horn? I'd recommend a VV-VI, later production with the floating horn--Serial 54501 and beyond.larryh wrote:I am cutting back on the amounts of records from the earlier acoustic period but don't quite want to not still play some... Larry
Similar size Columbia table-tops are also worth considering.
brianu
epigramophone wrote:Many British collectors, myself included, rate the HMV Model 130 the best table gramophone ever made. It has the No.5a soundbox, the No.32 double spring motor and a horn of exponential shape. Not easy to find in the USA but well worth seeking out.
is there much difference between the 130 and the 150? is it just size?
outune
Epigramophone is right on-- The 130 was my very first phonograph -- purchased in 1976 in Arlington, VA. It has incredible sound. The 5A reproducer is loud and clear. I don't play it as much as I used to as it has taken a backseat to my outside horn machines, but it is really a great machine and not too bad to move around if needed.
Brad Abell
Brad Abell
tomb
A nice VV-50 in oak would be a solid machine if the reproducer is rebuilt. It looks nice and sounds well. Not as good as bigger machines Tom
The 130 and 150 are identical in size. The main differences are a more rounded case and a different turntable brake. Most 150's seem to have been exported, probably to the outposts of the British Empire, making them rarer in the UK than the 130. The 150 looks like this :brianu wrote:epigramophone wrote:Many British collectors, myself included, rate the HMV Model 130 the best table gramophone ever made. It has the No.5a soundbox, the No.32 double spring motor and a horn of exponential shape. Not easy to find in the USA but well worth seeking out.
- hmv-150.jpg (24.59 KiB) Viewed 1548 times
