A rarely seen attachment used on Phonographs & Graphophones. The Phon-Arm attachment first appears in the September 1907 issue of Talking Machine World for $7.50 for use on Edison Standard, Home and Triumph models. Slightly later for Columbia BK,BE and BF models. However, it doesn't seem to be advertised for long. By February 1908 it was reduced in price to $6 and then faded away.
There is an example shown (for the Phonograph) in George & Tim's book "Gadgets,Gizmos & Gimmicks" (page 58).
Funnily enough, the ultra rare Devineau Biophone attachment is advertised at this time in TMW also and shown back to back in their book.....just coincidence.
The attachment I show uses a Victor horn type elbow (with Y clamp); Not a "slip in" elbow as shown in the 1908 ad. There is also a cast iron finger with a slight dimple on one side that pivots from side to side and held by one big nickel plate slotted screw.
It is hard to ascertain if there is a cast iron finger on the Phon-Arm shown in the book (on a Phonograph).
Of interest, the January 1908 TMW Phon-Arm ad states "improved construction allows horn to be turned in a complete circle"."Users appreciate this". Did users really appreciate this or did Victor for possible infringement...?.
Could this be the Graphophone version I show here..??. Can any member shed more information on this please?.
Phon-Arm Attachment
gramophone78
Re: Phon-Arm Attachment
It's interesting, but needs the front cabinet hook portion to work...
Also, it explains why horns are sometimes found with the ends cut off...
gramophone78
This example appears to have had no "hook" as shown in the illustrations.Curt A wrote:It's interesting, but needs the front cabinet hook portion to work...
Hoping a member can post pics of another like this to compare.
phonohound
The example you post is for an Edison Standard. I have this very same one. The attachment swingarm fits between the Standard swingarm feedscrew. I posted my example as a featured phonograph. Your example is missing the tonearm and u-connector from the tone arm to the reproducer. See link for more details and pics.
http://forum.talkingmachine.info/viewto ... =2&t=21940
Id be happy to answer any questions. Your example is now the 3rd one I I know of for a Standard. I dont know of any for Graphophones.
Scott
Scott
gramophone78
Scott, thank you very much for the information and thread link. I tried a search before posting. However, I searched under "Phon-Arm" as written in the ads...phonohound wrote:The example you post is for an Edison Standard. I have this very same one. The attachment swingarm fits between the Standard swingarm feedscrew. I posted my example as a featured phonograph. Your example is missing the tonearm and u-connector from the tone arm to the reproducer. See link for more details and pics.
Scott
Your post explains everything as I was wondering about case sizes and how they would be adjustable to accommodate accordingly.
Regarding the tonearm....what holds the arm into the bracket..?.
If memory serves...I believe the example in the book is also on a Standard. Is that yours or is that the third one known..?. I guess I should have cleaned it a bit before I posted it.
Thanks so much again for this information.
