How to play Marconi Velvet Tone records?
52089
Post by 52089 »
I recently bought a very nice group of records that included one Marconi Velvet Tone disc. These are sort of like an early version of flexi-discs. The material seems closer to vinyl than shellac. Because of that, you're not supposed to play these with a steel needle. A special gold-plated needle is recommended, but who has those? (Most of these, this one included, are found with significant wear from owners who used steel needles on them.)
What is the recommended method for playing these now? Would thorn or fiber needles be OK, or are these best played with modern equipment only?
Joseph Clack
Personal Text: records galore
Re: How to play Marconi Velvet Tone records?
Post by Joseph Clack »
I've got a couple and they play well on a modern machine.
Wolfe
Post by Wolfe »
It's a celluloid record. They were taken off the market due to excessive wear problems and using a gold plated needle in heavy mechanical soundbox isn't going to make much difference.
Trailer needles, recommended for flexible records such as Filmophones, might be worth a try.
Post by Phonofreak »
I would not play these acoustically. These should be played on a modern turntable. These records are very scarce, and few survived. After they were torn to shreds from steel and the gold needles, most were tossed in the trash. To me, these are more of a curio than a serious record to play.
AmberolaAndy
Post by AmberolaAndy »
I only have one of these records in my collection, and it plays fine on a modern turntable.
MisterGramophone
Personal Text: Guess I’m OrthoFan’s Apeophone now!
Post by MisterGramophone »
You need a Marconi gold-plated needle and a gramophone that plays laterals.
If I were a troll, I would not post on the Talking Machine Forum; I would live under a bridge, post on Reddit, and eat goats for dinner!
MisterGramophone
Phonofreak wrote: Tue Mar 13, 2018 7:06 pm I would not play these acoustically. These should be played on a modern turntable. These records are very scarce, and few survived. After they were torn to shreds from steel and the gold needles, most were tossed in the trash. To me, these are more of a curio than a serious record to play.
These will be shredded even by the needles designed for them? How bad was this design???
Liamhamb30
Post by Liamhamb30 »
MisterGramophone wrote: Sat Jun 28, 2025 12:56 pm
The base material for Marconi records isn't like normal shellac records, it's almost like a laminated cardboard. I'd compare it most to Durium records from the 30s. At this point, they're too valuable and old compared to other "cardboard" records to risk being played by a heavy steel needles. Best to be cautious and use modern turntables with lightweight pickups.
Liam Hood
MisterGramophone
Liamhamb30 wrote: Mon Jun 30, 2025 10:18 pm
So, I can’t use an original Marconi gold-plated needle to play Marconi records on an original gramophone?
