Victor Service Instructions— Early triple spring motors
MarkELynch
Post by MarkELynch »
Some of you may find this spring servicing instructions useful, it was sent by Victor to its dealers.
Mark
Phono-Phan
Re: Victor Service Instructions— Early triple spring motors
Post by Phono-Phan »
Great information. Thanks for posting it.
Ken Brekke
alang
VTLA
Personal Text: TMF Moderator
Post by alang »
Yes, great information. Very helpful. It also finally answers the question how to install a new spring that comes with a retaining ring. No need to manually wind it in, just push it into the spring barrel.
Thank you very much!
Marco Gilardetti
Post by Marco Gilardetti »
alang wrote:Yes, great information. Very helpful. It also finally answers the question how to install a new spring that comes with a retaining ring. No need to manually wind it in, just push it into the spring barrel.
The replacement springs that I've bought so far don't come with that huge "C"-shaped retainer seen in fig. 5, but are retained with a circle of iron wire. Not only the rivet slot is not exposed, but the whole spring+retainer combo may fit inside the barrel with no possibility of pushing away the retainer as explained. Also, I would always be in doubt that the rivet and the slot have correctly engaged. Personally I wouldn't do it that way in any case.
These instructions seem to me mainly a theoretical essay about how these operations would be performed by immaterial ghosts in an ideal world. Fig. 4 almost makes me laugh and I challenge anyone at taking a picture of barrels A and BC in the same position without barrel BC rocketing out of the window. Fig. 13, where the shaft is re-inserted without even pushing it, but actually gently holding it from above, delivers a similar comic effect.
Thanks a lot in any case for posting these pages, Mark, they're a very interesting period document!
