C250/C19 Database Survey - Updated 3/21/2018
fran604g
Post by fran604g »
Hi folks,
My original "C250/C19 database survey" post had grown to the point in which I had made several significant alterations to my original questionnaire questions, so I've decided to do this 2nd, UPDATED post, to reflect my current needs.
I will continue to update my spreadsheet to reflect new entries, as before.
The "old" page can be found here: http://forum.talkingmachine.info/viewto ... =2&t=16837
Those of you who have already submitted your information in the past, you don't need to do it again, the original post has not been deleted, but moving forward, all new participants should submit their information here.
The following are particular features that I am observing on the Edison C250/C19 Chippendale Phonographs, please number your responses accordingly.
1. What is the Model Designation? "C 250" or "C 19"
2. What is the Serial Number? "SM-??????"
3. Which finish does the motor plate have?:
3A) "Maroon" with gold pin striping (as the B 250 had).
3B) "Black with Maroon decals" (the maroon decals are applied near the speed control knob, and at the lower left hand corner of the motor plate".
3C) "Black ONLY with pin striping present".
3D) "Black with NO pin striping".
4(A) Are there drip pans present under the governor, innermost spring barrel (found only on the earliest C 250's) AND: are they finished in "Maroon", or "Black”?
4(B) Does the top of the motor plate have a continuous flat surface, or is there a large concentric circular depression (located beneath the turntable) present? Please state "Flat" or "Circular".
4(C) Does the governor (located beneath the turntable) have "2 springs" or "3 springs"?
4(D) Which finish is on the reproducer, horn throat, and other hardware on the motor plate? “Gold plated”, or “Gun-metal” (AKA "antique bronze")?
5. Which "Official Laboratory Medallion" is present?
5A) "P-1" = Pentagonal flange with circular boss stating: “The $250 Diamond Disc Phonograph is the Official Laboratory Model Thos A Edison”
5B) "P-2" = Pentagonal flange with circular boss stating: “The C250 Diamond Disc Phonograph is the Official Laboratory Model Thos A Edison”
5C) "R-1" = Round emblem stating: “The Model 250 Diamond Disc Phonograph is the Official Laboratory Model Thos A Edison”
5D) "R-2" = Round emblem stating: “Diamond Disc Official Laboratory Model Thos A Edison”
6. Which form of record storage is present:
6A) 2 Drawers divided into 5-compartments.
6B) 2 Drawers divided by individual record "slots", each numbered 1-36.
6C) 2 Shelves divided by individual record "slots"; AND: Are the corresponding numbered strips for the shelves: 1-36 on both strips OR are they numbered 1-36 on the top strip and 37-72 on the bottom strip?
7. Cabinet Wood Type: "Mahogany" or "Oak"
8. Is an "Electric Automatic Stop" (AKA Duncan Stop) present on the motor plate? Yes/No
9. Please list any dealer tags or decals present anywhere on the cabinet: Name/Address, location on machine, etc.
10. Are there any original dated sales receipts/shipping documentation, etc. with the machine? (Dates are particularly noteworthy)
11. Is there Grille cloth present? AND: What is the Color?
12. Is the record storage door held open by a rod at the top, center, or the bottom of the cabinet door?
13. What is the "Cabinet Factory No." - (if present) as found on the sticker inside the horn compartment
Your participation and comments are truly appreciated.
Thank you all,
Fran
vod_kanockers
Personal Text: The Dude Abides
Re: C250/C19 Database Survey - Updated 3/21/2018
Post by vod_kanockers »
1. What is the Model Designation? C 19
2. What is the Serial Number? SM-100567
3. Which finish does the motor plate have?: 3D
4(A) Are there drip pans present under the governor, innermost spring barrel (found only on the earliest C 250's) AND: are they finished in "Maroon", or "Black”? No
4(B) Does the top of the motor plate have a continuous flat surface, or is there a large concentric circular depression (located beneath the turntable) present? Please state "Flat" or "Circular". ?
4(C) Does the governor (located beneath the turntable) have "2 springs" or "3 springs"? ?
4(D) Which finish is on the reproducer, horn throat, and other hardware on the motor plate? “Gold plated”, or “Gun-metal” (AKA "antique bronze")? Gun-metal
5. Which "Official Laboratory Medallion" is present? 5D
6. Which form of record storage is present: 6C both shelves numbered 1-36
7. Cabinet Wood Type: Mahogany
8. Is an "Electric Automatic Stop" (AKA Duncan Stop) present on the motor plate? No
9. Please list any dealer tags or decals present anywhere on the cabinet: Name/Address, location on machine, etc. None
10. Are there any original dated sales receipts/shipping documentation, etc. with the machine? (Dates are particularly noteworthy) No
11. Is there Grille cloth present? AND: What is the Color? Yes, Gray
12. Is the record storage door held open by a rod at the top, center, or the bottom of the cabinet door? Top
13. What is the "Cabinet Factory No." - (if present) as found on the sticker inside the horn compartment none
I am doing this by memory as the phonograph is covered in plastic while workmen are painting. I will verify some of these and update if I spoke incorrectly. Good work on the database Fran.
C19 Chippendale approx. 1920
Last edited by vod_kanockers on Sun Apr 15, 2018 12:14 pm, edited 1 time in total.
fran604g
Post by fran604g »
Thank you very much for the kind words, and welcome to the forum! What a great way to kick-off this "new" data collection thread.
I'll enter your C 19 into my spreadsheet, and when you check back, I'll amend your entry as needed.
Best,
Fran
CMac1974
Personal Text: Record, Machines, Records, Machines.... Decisions Decisions!
Post by CMac1974 »
2. What is the Serial Number? "SM-113623"
3. Which finish does the motor plate have? 3D
4(A) Are there drip pans present under the governor, innermost spring barrel (found only on the earliest C 250's) AND: are they finished in "Maroon", or "Black”? There are none
4(B) Does the top of the motor plate have a continuous flat surface, or is there a large concentric circular depression (located beneath the turntable) present? Please state "Flat" or "Circular". Circular
4(C) Does the governor (located beneath the turntable) have "2 springs" or "3 springs"? 2 springs
4(D) Which finish is on the reproducer, horn throat, and other hardware on the motor plate? “Gold plated”, or “Gun-metal” (AKA "antique bronze")? Gold Plated
6. Which form of record storage is present: 6C 1-36 on both shelves
7. Cabinet Wood Type: "Mahogany" or "Oak" Mahogany
8. Is an "Electric Automatic Stop" (AKA Duncan Stop) present on the motor plate? Yes/No NO
9. Please list any dealer tags or decals present anywhere on the cabinet: Name/Address, location on machine, etc. Dealer Tag Butler's Marion's Musical Center
10. Are there any original dated sales receipts/shipping documentation, etc. with the machine? (Dates are particularly noteworthy) None Available
11. Is there Grille cloth present? AND: What is the Color? There was, it was Gold
12. Is the record storage door held open by a rod at the top, center, or the bottom of the cabinet door? Center
13. What is the "Cabinet Factory No." - (if present) as found on the sticker inside the horn compartment #33
CMac1974
Post by CMac1974 »
Sorry I have 2 a C-19 and a C-250
1. What is the Model Designation? C 250
2. What is the Serial Number? "SM-61728"
4(A) Are there drip pans present under the governor, innermost spring barrel (found only on the earliest C 250's) AND: are they finished in "Maroon", or "Black”? None Present
4(C) Does the governor (located beneath the turntable) have "2 springs" or "3 springs"? 2 Springs
5. Which "Official Laboratory Medallion" is present? 5C
6. Which form of record storage is present: 6A
9. Please list any dealer tags or decals present anywhere on the cabinet: Name/Address, location on machine, etc. None Available
11. Is there Grille cloth present? AND: What is the Color? None Present
12. Is the record storage door held open by a rod at the top, center, or the bottom of the cabinet door? Bottom
13. What is the "Cabinet Factory No." - (if present) as found on the sticker inside the horn compartment #19
fran604g
Post by fran604g »
Thank you, CMac1974, and welcome to the Talking Machine Forum!
I've added your information to my spreadsheet.
Best regards,
Fran
kschill55
Personal Text: Proud owner of C250
Post by kschill55 »
1. What is the Model Designation? C250
2. What is the Serial Number? SM-51899
3. Which finish does the motor plate have?: 3D) Black with NO pin striping.
4(A) No drip pan
4(B) Flat
4(C) 2 springs
4(D) Gold plated
5. Official Laboratory Medallion is R-1 Round emblem stating: “The Model 250 Diamond Disc Phonograph the Official Laboratory Model Thos A Edison”
6. 6A) 2 Drawers divided into 5-compartments.
7. Cabinet Wood Type: Oak
9. No store tags
10. No stickers
11. Is there Grille cloth present? AND: What is the Color? Yes, Gold/Brown
12. Door rods are at Bottom
13. Cabinet Factory No.18
Karl Schill
Palmyra, Pa
[email protected]
fran604g
Post by fran604g »
kschill55 wrote:1. What is the Model Designation? C250
4(A) No drip pan
4(B) Flat
4(C) 2 springs
4(D) Gun-metal
9. No store tags
10. No stickers
Karl Schill
Palmyra, Pa
[email protected]
Thank you for your entry, Karl. I see you're relatively new to the forum - let me be the first to welcome you in and encourage you to visit often - don't be shy!
I do however have one question, re. Q4: are you sure the finish is "gunmetal"? It should be all gold plated hardware on a Chippendale of this vintage. Is it perhaps only the reproducer that's gun-metal finished? It's not uncommon for reproducers to be swapped out over time.
Happy Holidays,
Fran
Bcaste1
Personal Text: Kansas City Edison C250 owner
Post by Bcaste1 »
2. What is the Serial Number? "SM-19865
4(A) Are there drip pans present under the governor NO
4(B) Does the top of the motor plate have a continuous flat surface FLAT
4(C) Does the governor (located beneath the turntable) have "2 springs" 2
9. Please list any dealer tags or decals present anywhere on the cabinet: Name/Address, location on machine, etc. From 1012 Grand KANSAS CITY
10. Are there any original dated sales receipts/shipping documentation, etc. with the machine? (Dates are particularly noteworthy) NO
11. Is there Grille cloth present? AND: What is the Color? Not original
13. What is the "Cabinet Factory No." - (if present) as found on the sticker inside the horn compartment no sticker
fran604g
Post by fran604g »
Bcaste1 wrote:1. What is the Model Designation? C250
Thank you! Nice Chippendale, and I see you have a set of the hard to find record file dividers, congratulations.
Best,
Fran
