Every time I try to crank the motor it cranks a bit then loses it's tension and winds down uncontrollably. Any tips?
Pictures provided to see if anyone can see a problem
Thanks
V6
trouble with standard A motor
victorthesixth
- motor2.jpg (118.45 KiB) Viewed 2889 times
- motor1.jpg (130.79 KiB) Viewed 2889 times
52089
Re: trouble with standard A motor
The spring is probably broken.
victorthesixth
How do I tell?
tomb
It could be a little gear in the middle of the motor that is slipping. Wind it up a bit holding different gears and work your way out. That is if the spring holds tension. You may have a gear slipping which will not engage the governor. Try holding the big gear to wind it. If it lets loose and you can hear it slip inside the spring canister than you have a bad spring. Please wear gloves when getting into springs and gears.. Sometimes the spring inside the canister can slip off their pin when they unwind and slip but most of the time they are broken. You have to open it up to check. Tom
52089
If you're winding it and you hear a rapid sh-sh-sh-sh-sh-sh sound, that's the broken spring rotating in the barrel.
You can disassemble the motor and open the spring barrel to be sure, or just send it out to one of the pros to check it for you. Springs can sometimes be repaired depending on where they break, but you might as well just buy a new spring.
victorthesixth
Which little gear? Thankstomb wrote:It could be a little gear in the middle of the motor that is slipping. Wind it up a bit holding different gears and work your way out. That is if the spring holds tension. You may have a gear slipping which will not engage the governor. Try holding the big gear to wind it. If it lets loose and you can hear it slip inside the spring canister than you have a bad spring. Please wear gloves when getting into springs and gears.. Sometimes the spring inside the canister can slip off their pin when they unwind and slip but most of the time they are broken. You have to open it up to check. Tom
tomb
If you look straight down in the motor there is a little drive gear that goes with a larger gear in the middle towards the bottom. That gear is pressed on the shaft and sometimes comes loose. I do not have a good picture of it available Look straight down in your motor and it looks like the one attached to the large gear. Also I can not tell but it looks like the small gear that is attached to the main drive gear is worn. That may be slipping. It is hard to tell for your picture but the first thing to check is your spring which is the most common. Tom
- Lucius1958
Looks like a Standard B motor to me.
But the diagnosis is the same: if it's not a broken spring, it's a loose gear.
Hard to tell from your photos, but it looks like you've got some really bad gears. Can you do a close-up shot on the gears? Aside from that possibility, you have a broken spring. If you wind it, with the motor stopped, and hear the spring tension release, but see no parts spinning out of control, then the commotion is within the spring barrel and the spring is broken.
- Lucius1958
Agreed: that intermediate gear looks pretty chewed up.JerryVan wrote:Hard to tell from your photos, but it looks like you've got some really bad gears. Can you do a close-up shot on the gears? Aside from that possibility, you have a broken spring. If you wind it, with the motor stopped, and hear the spring tension release, but see no parts spinning out of control, then the commotion is within the spring barrel and the spring is broken.
