I'm looking for a replacement spring for my Columbia 112, and I wonder if the measurements must be absolutely identical to the old one. I was told the spring for this motor is 25mm wide, and fully coiled it measures 74mm. Would a 70mm one suffise? I'm trying to find it a bit cheaper, that's why I'm wondering.
Thank you in advance!
Garrard 50 replacement spring measurements
- GabrielePfr
Phono48
Re: Garrard 50 replacement spring measurements
A few mm either way won't make much difference, it will just mean the motor won't run for quite as long, but it should still cope with a 12" side without rewinding.
- GabrielePfr
Thank you! Good to know.Phono48 wrote:A few mm either way won't make much difference, it will just mean the motor won't run for quite as long, but it should still cope with a 12" side without rewinding.
According to my Vulcan Mainspring Price List, the details are :
Width 1" x Thickness 0.026" x Length 15'6" (25 x 0.65 x 4725 mm)
