Hi,
Does anyone have a spare motor , i only need the drive gear that has brass drive gear pressed on to shaft and lower pulley.
Thanks Eric
WANTED : Misc motor parts for Edison home
- ehs004
- studebakerphonos
- Personal Text: Skilled Craftsman produce radio cabinets at RCA Victor in Camden, N.J.
Re: WANTED : Misc motor parts for Edison home
Could you post a picture?
I get confused with which one is which.....
It sounds like you are needing the small 19-tooth gear-- It is a press-on gear. They frequently crack and spin freely on the shaft-- Ron Sitko makes a replacement 19-tooth gear that is secured by a set-screw. That may be your easiest solution.
Brad Abell
Brad Abell
- ehs004
Brad ,
Yes!!!
Yes!!!
Just call Ron and ask for the 19-tooth Home gear... He'll know exactly what you need.
Brad Abell
Brad Abell
- ehs004
Pictures posted , can you help?studebakerphonos wrote:Could you post a picture?
Thanks Eric
- studebakerphonos
Thought I had one, but sorry, I do not.
Ron is the guy, he has the pulley too !
- ehs004
Thanks for the replies , talked to Ron today and my parts are on the way! Hows that for a rhyme?
Thanks Eric
Thanks Eric
