Can Anyone Indentify This portable Canadian Grafonola.
ThorOdinson1
Personal Text: ThorOdinson3
Post by ThorOdinson1 »
Seen this For Sale At a Antique Shop wanted to know if this is Orignal or not . Thanks Morgan.
Re: Can Anyone Indentify This portable Canadian Grafonola.
Post by Phonofreak »
This is a Columbia Model 140 portable . This came out in 1924. Unfortunately, the original price is not listed in my Columbia book. It's a cool little machine, and if the price is reasonable, I would get it. What are they asking for it?
Post by OrthoFan »
Phonofreak wrote:This is a Columbia Model 140 portable . This came out in 1924. Unfortunately, the original price is not listed in my Columbia book. It's a cool little machine, and if the price is reasonable, I would get it. What are they asking for it?
Hi Harvey -- From what I've been able to spot, they were $50.00.
FROM: https://archive.org/stream/talkingmachi ... 7/mode/2up
ThorOdinson1
Thank you :) the machine is listed at $129.00,but theres a problem with the motor 4 winds and then Clank.
Lucius1958
Post by Lucius1958 »
ThorOdinson1 wrote:Thank you :) the machine is listed at $129.00,but theres a problem with the motor 4 winds and then Clank.
Sounds like the spring is broken near the outer end.
If you can talk them down to $100.00 or less, that wouldn't be too bad. Also, check the arm and reproducer fittings because they are pot metal and have the binding problems. Also, check for cracks in the pot metal.The motor is a simple single spring that shouldn't be too expensive to have repaired,
