Thanks in advance
Good evening sir,I have a HMV 101B and I receantly restored it. The same very bearing was missing since I opened up the motor and it doesn't seem to cause any harm or malfunctions,it rests pretty good in the brass slot. Judging by the lack ofLagge0101 wrote:I recently lost the ball bearing that supports the turntable spindle on my HMV 101 motor model 410. I have been looking everywhere for it, but cant seem to find itI came to the conclusion that its better if I buy a new ball bearing of the internet. Does anyone know the size of the ball bearing? From what i’ve heard it is a rather small ball bearing maybe not more than 1mm. I want to have the original size when putting the motor back together.
Thanks in advance
Yes, the problem is still though that i need a new ball bearing and the size of the ball bearing is to me unknown.Garret wrote:I would add the ball bearing. It was designed that way for a reason.
Garret
gramophone-georg wrote:Post a pic of your motor and where the spindle goes into the motor frame. Wonder if a Victor ball is the same.
The ball bearing at the bottom of a Victor Electrola motor spindle is .188" (3/16"). Not sure if it's the same as yours, but if it fits into the hole, it will likely work, I would think.Lagge0101 wrote:Does anyone know the size of the ball bearing?
box_o_records23 wrote:Good evening sir,I have a HMV 101B and I receantly restored it. The same very bearing was missing since I opened up the motor and it doesn't seem to cause any harm or malfunctions,it rests pretty good in the brass slot. Judging by the lack ofLagge0101 wrote:I recently lost the ball bearing that supports the turntable spindle on my HMV 101 motor model 410. I have been looking everywhere for it, but cant seem to find itI came to the conclusion that its better if I buy a new ball bearing of the internet. Does anyone know the size of the ball bearing? From what i’ve heard it is a rather small ball bearing maybe not more than 1mm. I want to have the original size when putting the motor back together.
Thanks in advance
wear marks on the spindle and the fact that I couldn't see what any fresh wear marks on it(used it daily from late february till today and serviced it for research) I can say it's not an urgent thing to fix. Till you find a matching bearing I'd reccommend greasing it very well. Best regards Alexander
soundgen wrote:box_o_records23 wrote:Good evening sir,I have a HMV 101B and I receantly restored it. The same very bearing was missing since I opened up the motor and it doesn't seem to cause any harm or malfunctions,it rests pretty good in the brass slot. Judging by the lack ofLagge0101 wrote:I recently lost the ball bearing that supports the turntable spindle on my HMV 101 motor model 410. I have been looking everywhere for it, but cant seem to find itI came to the conclusion that its better if I buy a new ball bearing of the internet. Does anyone know the size of the ball bearing? From what i’ve heard it is a rather small ball bearing maybe not more than 1mm. I want to have the original size when putting the motor back together.
Thanks in advance
I am astonished your machine works without the bottom ball bearing are you sure it is missing , lack of the ball bearing stops the machine dead when playing a record
