Henry Seymour Catalogue
Henry Albert Seymour (1861-1938) was the leading British pioneer in the field of improvements to sound reproduction.
His book "The Reproduction of Sound", published in 1917, was the definitive work on the subject at the time.
In 1923 Ellis Michael Ginn and his brother-in-law David Phillips set out to create the perfect gramophone, and it was to Henry Seymour that they turned for guidance. The Seymour Superphone was their inspiration, and their early EMG machines made extensive use of Seymour's components.
I recently acquired a copy of Henry Seymour's catalogue, which I reproduce here to share with you :
Re: Henry Seymour Catalogue
Post by OrthoFan »
Many thanks for posting this. I see that the Seymour Loud-Speaker horn ...
... anticipates Columbia's Plano-Reflex design ...
...by several years!
emgcr
Post by emgcr »
Many thanks Roger---extremely interesting and here are some photos of one of his Superphones.
emgcr
Post by emgcr »
....and a soundbox box.......
Lucius1958
Post by Lucius1958 »
It would be interesting to make a video comparison of the "Superphone" against other machines of the period; depending on how the "Hornite" diaphragm has aged versus mica diaphragms.
Oedipus
Post by Oedipus »
Yes, it is impossible to assess synthetic diaphragms like the Hornite and the Cliftophone, because we just don't know how they have deteriorated with age.
The Seymour loudspeaker does not anticipate the Columbia Plano-Reflex, because it does not have flats on the outside of the bends. It is simply made up of sections of tapered tube joined at angles, like the Waveola horn.
Post by OrthoFan »
Oedipus wrote:...The Seymour loudspeaker does not anticipate the Columbia Plano-Reflex, because it does not have flats on the outside of the bends. It is simply made up of sections of tapered tube joined at angles, like the Waveola horn.
Many thanks for the clarification. I enlarged the image of the loudspeaker horn and can (now) see what you mean.
condenser
Personal Text: Gramophone collector
Post by condenser »
Is there any chance of putting the Seymour catalogue back on? I would love to see it. I have a Seymour Superphone.
condenser wrote: Fri Nov 18, 2022 1:32 am Is there any chance of putting the Seymour catalogue back on? I would love to see it. I have a Seymour Superphone.
It will take me a little time to find and scan it again, but if you are an APS member it can be viewed on their website.
Meanwhile I am sure that we would all like to see pictures of your Seymour Superphone.
Roger.
emgcr
Post by emgcr »
I am not sure if this might be the catalogue referred to but, if not, may still be of interest ? Sorry it is back-to-front !
