European Coin Operated Gramophone. Help with Identification?
Lampman5
Personal Text: ID Required
Post by Lampman5 »
Photo 3976.jpg (73.67 KiB) Viewed 3235 times
Hello Everyone, my first post.
I purchased this coin operated machine a couple of weeks ago and have not been able to determine the maker. The coin plate would lead me to believe it is either German or Austrian this is only a guess. Machine has issues (wrong crank, later reproducer and unfortunately it is missing the entire coin mechanism but still works and has a great look. Any information on this machine would be greatly appreciated?
Photo 3977.jpg (79.18 KiB) Viewed 3235 times
Photo 3970.jpg (71.94 KiB) Viewed 3235 times
Menophanes
Re: European Coin Operated Gramophone. Help with Identificat
Post by Menophanes »
A very minor point: the heller (six of which, in the form of three two-heller pieces, had to be inserted) was an Austrian coin. Were there any specifically Austrian manufacturers? Of course the machine could have been produced in a German or Swiss factory and specially calibrated for Austrian currency.
Oliver Mundy.
Post by soundgen »
You really need to take some pictures of the motor may help?
jamiegramo
Post by jamiegramo »
I suspect this may be Swiss. It has a similar 'stacked' appearance to a couple of Swiss coin-ops I have seen. As Soundgen says we really need to know a bit more about the motor... it might be Paillard?
Jamie
Lampman5
Post by Lampman5 »
Thanks Very Much !! That is the closest I have come so far in identifying this machine. The pictures look very similar.
I have attached a picture of the motor and the section that would have held the coin mechanism. There are no additional holes drilled in the top or side of the machine so guessing it is the original motor. Looks like it was altered /butchered when the coin mechanism was removed.
I doubt I will ever locate the parts needed to restore it to its original state but would love to find out more information on this unique machine.
Thanks Again
Photo 5294.jpg (84.55 KiB) Viewed 2765 times
Photo 5295.jpg (71.29 KiB) Viewed 2765 times
jamiegramo
Hi Steve,
To be more certain there are 2 members (at least) on here who are excellent at identifying European motors and machines. 'Jaso' and 'tinovanderzwan', perhaps you could private message them and ask them to look at this thread?
I don't think you'll find the missing coin mech but maybe if you can find someone with a similar machine it could be copied. It would be worth a try.
Jamie
Jamie
Lampman5
Re: European Coin Operated Gramophone. Help with Identification?
Post by Lampman5 »
It has been a while but stumbled on the same coin operated machine with a slightly different horn that sold in November in a German auction.
Not sure what it sold for and unable to see the internal workings but one more step forward in identifying this machine.
Coin-Operated Gramophone, c. 1914
Brass plaque "Einwurf 3mal 2 Heller", two-tiered wood case with coin drawer in lower part, mica reproducer, large metal horn, outside repainted, Ø 22 ½ in., works, coin mechanism sticks occasionally.
Münzgrammophon, um 1914
Messingschild "Einwurf 3mal 2 Heller", zweistufiges Holzgehäuse, Unterteil mit Münz-Schublade, Glimmerschalldose, großer Metalltrichter, außen neu lackiert, Ø 57 cm, funktioniert, Münzmechanik hakt manchmal.
See link: https://www.lot-art.com/auction-lots/Co ... 11.21-team
