Wanted: Gold no.4 soundbox
- Ahmed
On the hunt for a gold HMV no.4 in reasonable condition
Re: Wanted: Gold no.4 soundbox
a gold No 4 , that is a very difficult ask but you can easily convert an ordinary no 4 by coating with gold foil , if you have a spare no 4 , take it apart and then coat the plated part with gold foil
https://en.wikipedia.org/wiki/Gilding
It's quite easy to do , you coat the part to be gilded with French Polish allow to dry slightly and lay the foil on the shellac allow to dry and it can then be gently polished , you can then darken the gilding if required using a further addition of a darker shellac , the beauty of it is that is is 100% reversible
- Ahmed
Thanks Mike, that's probably my best bet. Will keep you posted how it goes!
A simpler method is to coat the nickel surface with amber shellac...
