I first restored the reproducer with new gaskets and back rubber flange. I tried my hand at boiling the old one in wintergreen oil to soften it up with mixed results, needless to say my time is worth more than that.
Here are a couple of photos of the process. I'll tell you, the hardest part of the whole thing was hooking the springs back into the barrels. These pre-clip Victrolas require a little bit of a wrestling match if you're going to reach the finish line for sure.
These two shots are just to show the shape of the nickel. This came completely clean with some #0000 steel wool.
I'm betting a bit of kerosene would have been an easier way to clean. I used Gojo shop wipes and then rags with WD40 to cut through the real hardened grease on the springs.
Tried to get a shot of the Victor logo but didn't quite come out. I was so happy to find no corrosion or cracks in the springs.
Packing the springs back in was tough but I prevailed. They got a good dose of new grease and a little bit of motor oil before reassembly.
After reassembly I oiled her up to test her out. She behaved perfectly! I opened her up one more time to give everything that makes contact with something else a bit of grease or oil. Now she purrs like a kitten and doesn't give my family a heart attack!
All finished! Now I'll get to work on the cabinet and see if I can find a couple of door knobs that appear to be missing.
