Tip to remove orthophonic rubber back flange?
stetam
Post by stetam »
Any advise on removing the hardened rubber flange without cracking the housing? Drilling it?
Stetam
Re: Tip to remove orthophonic rubber back flange?
I suspect that's the way to go, you have to carefully destroy it but by bit so not to force the metal neck around it, or it may break (mazak).
stetam
Post by stetam »
Yep, just got done drilling it all the way around and got it out.
phonojim
Post by phonojim »
I use a heat gun to soften the old rubber. It comes right out when heated.
Jim
Dischoard
Post by Dischoard »
I'll have to get a heat gun, what setting do you use?
