Good Source for Screws and Fasteners
MarkELynch
Post by MarkELynch »
If you can’t locate original hardware here is a source for some common and some hard to find machine screws, wood screws and fasteners. They even have a section entitled “Phonograph Screws” but it isn’t clear why. Nevertheless, there are many choices of fasteners with different finishes, materials, head type. Most are available with a slotted head as found on our old phonos.
https://www.blacksmithbolt.com/store/c/ ... crews.aspx
Mark
oliver
Personal Text: always in the mood for a new basket case phonograph
Re: Good Source for Screws and Fasteners
Post by oliver »
Thanks a lot for your post.
AudioFeline
Personal Text: Sounds good to me...
Post by AudioFeline »
And FYI, Blacksmith Bolts are in Portland, Oregon, USA.
alang
VTLA
Personal Text: TMF Moderator
Post by alang »
Since shipping for small numbers of screws is multiple times their cost, I ordered a large variety of nickel plated slotted wood screws years ago. But like always, the screw you need is the one you don't have :x
MarkELynch
I’m reposting this hardware source for those that may not have seen it. Most recently they added some 5-40 slotted set screws that are suitable for Edison top works. They are nickel plated and slightly shorter but are a good substitute is old stock can’t be located.
Mark
MarkELynch wrote: Wed Mar 06, 2024 12:05 pm I’m reposting this hardware source for those that may not have seen it. Most recently they added some 5-40 slotted set screws that are suitable for Edison top works. They are nickel plated and slightly shorter but are a good substitute is old stock can’t be located.
Mark
They have black oxide also... https://blacksmithbolt.com/collections/ ... lack-oxide
