So, I have a 2/4 machine and currently have a Diamond B reproducer with it. I'm wondering- will a Model O reproducer play BAs as well as a Diamond B, or would I want to keep the Diamond B whenever I get the model O?
Also, the model O reproducer CAN play Amberol wax cylinders, right?
Thanks all,
Gunnar Anderson
Model O reproducer VS Diamond B for Blue Amberols
- Personal Text: Started collecting in August 2020, small collection of records
- Roaring20s
Re: Model O reproducer VS Diamond B for Blue Amberols
This is interesting to me too.
I'd like to hear from those who have both types of reproducers.
James.
James.
It will, but celluloid cylinders will more rapidly wear a flat on the sapphire stylus. That endangers any wax Amberols that you might play with that stylus. The Diamond B (and other diamond stylus reproducers) were intended to play celluloid. Best practice is sapphire for wax, diamond for celluloid.
- Roaring20s
So, I guess the next question is, is the "O" a better sounding reproducer than a "C" or a "H"?
James.
James.
- Mormon S
- Personal Text: "phono_fluff" on instagram
I do not own a model O reproducer, but simply based on the way they are built and from what I have heard, the model O should have a better sounds quality than a C or H because of the larger diaphragm, in the same way that a model N, R, and S does. When comparing the sound of a model N to a diamond C, the Diamond C is definitely better in sound quality, but of course you are restricted to celluloid 4 minute cylinders. The model O is as desired and expensive as it is because of its good sound, practicality (not needing to remove the reproducer and change settings) and relative rarity.
IMO, if you want to be able to play every type of cylinder most conveniently and at the best sound quality, you would want to have a model B for brown wax, a model O for 2 min and wax 4 min, and diamond C for 4 min celluloid.
- Roaring20s
Gunnar, thanks for starting this post.Mormon S wrote: Tue Oct 19, 2021 10:21 pm IMO, if you want to be able to play every type of cylinder most conveniently and at the best sound quality, you would want to have a model B for brown wax, a model O for 2 min and wax 4 min, and diamond C for 4 min celluloid.
Mormon, thanks for that input. That scenario is the way I thought it might be. I have that covered with my plans to max-out my Standard B. Of course the "B" reproducer will need a reducing ring for the horizontal carriage.
James.
I could not agree more.JohnM wrote: Tue Oct 19, 2021 9:55 pm It will, but celluloid cylinders will more rapidly wear a flat on the sapphire stylus. That endangers any wax Amberols that you might play with that stylus. The Diamond B (and other diamond stylus reproducers) were intended to play celluloid. Best practice is sapphire for wax, diamond for celluloid.
My sapphires don't go anywhere near celluloid cylinders so they will probably out live me.
This is reason my Amberola 1a has a Model M and Diamond A reproducer.
I learned the hard way many years ago and destroyed some really good wax Amberols by using a Model H on both wax and celluloid.
I mean, it's a slightly lesser quality model M, isn't it?Roaring20s wrote: Tue Oct 19, 2021 10:03 pm So, I guess the next question is, is the "O" a better sounding reproducer than a "C" or a "H"?
James.
That sounds good. However, I don't think I'll need a diamond B for a while- brown wax really doesn't show up in my area (north Midwest) and I'd bet conditions aren't too hospitable for it.Mormon S wrote: Tue Oct 19, 2021 10:21 pm I do not own a model O reproducer, but simply based on the way they are built and from what I have heard, the model O should have a better sounds quality than a C or H because of the larger diaphragm, in the same way that a model N, R, and S does. When comparing the sound of a model N to a diamond C, the Diamond C is definitely better in sound quality, but of course you are restricted to celluloid 4 minute cylinders. The model O is as desired and expensive as it is because of its good sound, practicality (not needing to remove the reproducer and change settings) and relative rarity.
I think you mean you won't need a Model B (sapphire) reproducer for a while.
A Diamond B is what you really should use if you intend playing Blue Amberols, and any other celluloid 2 or 4 minute cylinders in your collection.
For ordinary black wax 2 min cylinders all you'll need is a common Model C (sapphire) reproducer and appropriate retaining ring, or to play 4 min wax as well, a Model H or K will allow you to.
If it were me, I'd keep the Diamond B, and get a Model K with retaining ring.
The K and ring would be far cheaper than an O, and will play all your black wax while still delivering great sound quality.
