It has heavy oxidation.
How do I clean this horn?
Re: How do I clean this horn?
The best outcome would probably result from using a professional brass instrument repair person, such as John Duffy at the Horn House. Still, you can do nearly as well by using proper techniques and products. A number of them were recommended in this thread:
https://forum.antiquephono.org/topic/16 ... polishing/
Good luck!
Good luck!
Flitz Tarnish Remover
https://www.amazon.com/Flitz-BC-01806-I ... hdGY&psc=1
It's amazing at removing tarnish. Depending on the level of tarnish, it can work in just a few minutes. No scrubbing or buffing needed. After you use it, wash it off, then polish with your favorite brass polish.
Jerry - I'll be looking for that Flitz Tarnish Remover! Sounds great - - thanks!
stetam
Thanks for the info. Will give it a try. I have used Flitz on polishing aluminum and steel before with great results but never knew it made brass cleaner.
