Remember, you are talking to a guy who is dumb as dirt when I comes to gramophones ... this is my first one ... and for that matter, the first one I have ever seen in person.
I bought 400 needles because I was told to change the needle every time I play a record ... buy why?
Does the plastic (or what ever material these records are made of) really wear out the needle?
What happens if you don't change the needle .. will it kill the records?
Thanks!
Why do I need to change needles ?
- Personal Text: I repair toys to tractors
Re: Why do I need to change needles ?
The material of a 78 RPM record is a mix or resin and a mineral filler 25%/ 80% and the filler is abrasive with a percentage of silica or similar and it is this that forms the shape of the needle in the groove and wears it down by the end . The needle then has a couple of flat surface on that will damage the next record and besides will sound bad as well.
And yes it will damage the record.
Answered on the "other" forum...
- Steve
- Steve
Yes, ground slate will be that.recordmaker wrote: ↑Mon Apr 22, 2024 11:35 am The material of a 78 RPM record is a mix or resin and a mineral filler 25%/ 80% and the filler is abrasive with a percentage of silica or similar and it is this that forms the shape of the needle in the groove and wears it down by the end . The needle then has a couple of flat surface on that will damage the next record and besides will sound bad as well.
Steve,
I sent a message to the site administrator on the APS forum. Hopefully, he can help you out.
- Steve
JerryVan wrote: ↑Mon Apr 22, 2024 1:33 pmThanking you, Jerry!
Steve,
- Benjamin_L
- Personal Text: Honk, honk.
The APS forum is better, cough, cough.
I am still on the steep learning curve.
I didn't know how many forums or FB groups there were.
I was not even sure who sold parts of for that matter where to find them.
So but sure getting the hang of this.
Mike
Mike
But seldom used compared to this one...
